Hi i have capture using the pinnacle rtdv. While capturing i dinterlace my dv footage. When viewing my dv footage in fast scene it looks great. But after encoding it to mpeg using tmpegh, all fast scene look a bit blured out. While if i burn the same file on to a dvd and play it on my tv, it looks like how the the dv file did in the fast scenes.
How can i remove the blur in fast scenes when viewing it on a monitor.
thanks
Since your source is interlaced, and your de-interlacing it, you will get artifacts (motion blurring in your case). Leave it interlaced. This will look fine on your TV. On your PC however, you will see the interlacing. If your video card supports it, some players like PowerDVD, or WinDVD, will deinterlace for you on playback, minimizing the effect on a PC monitor. This works with MPEG video, not with AVI.
If you must deinterlace, and you don't like the motion blur, then you can try other methods of deinterlacing, which will introduce their own artifacts, like ghosting. There isn't really a good option to deinterlace true interlaced material, as they all leave something to be desired.Impossible to see the future is. The Dark Side clouds everything... -
Hi thanks for your reply. When playing the avi file , you do not see the motion blur.But the motion blur still apears even though i do not deinterlce it. Is there away to make my monitor true interlaced so i can get the video to display like it does on a tv.
Thanks -
Most newer monitors no longer use interlaced display modes. The flicker was too irritating on the eye. If your monitor is older, you may have a few interlaced modes. I wouldn't go there just yet though. If your not seeing this affect with your original AVI then there may be some other problem.
Check your field order. DV video is always bottom field first. If you get it wrong, you'll get a combing affect. It can also cause jerky video on panning, or high motion scenes.
Also make sure you TMPGenc settings are not set to deinterlace your output. It should be set to interlaced. The same as your input. I would also turn off any other filtering options until you correct the problem.Impossible to see the future is. The Dark Side clouds everything...
Can an interlaced file appear not to be interlaced on the monitor?
By rcavanah in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2011, 22:09 -
Interlaced.... or not?
By pgoelz in forum Capturing and VCRReplies: 29Last Post: 15th May 2011, 22:20 -
Interlaced or not
By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 26th Oct 2010, 09:17 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 09:16 -
Convert interlaced HD to interlaced SD with AVISynth
By jorbje in forum Video ConversionReplies: 19Last Post: 22nd Mar 2008, 18:48
