I have a nice Xvid that sounds like its audio is 5.1 surround sound and I want to know how to handle it when i try to encode it to DVD. I have two questions.
1. How can i tell if its has AC3 5.1 compression
2. How should I handle the sound when encoding so that i don't lose the 5.1 surround sound feature.
Thanks in advance,
VC
Results 1 to 11 of 11
This is so much fun!
open the file with nandub or virtualdubmod.
file > file information
if its ac3 it will say ac3 or unknown(tag 2000) -
Most of the Time AC3 is 5.1. There is Stereo AC3, but if its a rip, there would be no point in keeping the AC3 if it was stereo. If the AC3 was stereo, it would be better to convert to MP3.
No MP3 isn't DVD complient. If your rip is AC3, then just demux it. Encode the video with DVD Standards. And mux the AC3 with the MPEG-2 Video.
The reason I brought up the MP3, I was saying that the ripper would have better luck with MP3 if the original AC3 was stereo. So if you download a movie and its AC3 it will almost never be stereo, because the ripper would change that to MP3 to save space. The only reason to keep the AC3 is because its 5.1.
Check the avi with GSpot to see if it is in fact AC3. -
hi i was wonderin how can u hear the ac3 audio on your computer...which codec do u need to insttall....i have the ac3 filter...does that help in anyway
Also how can u exttract it into a wav or someother format which is dvd compliant?
thanks a million -
Originally Posted by romy_1986
AC3 is DVD compliant.
8)"Art is making something out of nothing and selling it." - Frank Zappa -
so zippy i can just add the .avi file with the ac3 audio in tmpgenc and encode it as a SVCD and the audio will work wen i put the ccd in my dvd player???
thanks once again -
If you're making an SVCD from an avi with AC3 audio, then it's best to extract the audio to a wav file first and use the wav file as the audio source for the encoder. I use Goldwave, here's a guide.
Or use gspot or avicodec
www.dvdrhelp.com/play#identify
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Need Help Encoding: Surround Sound Goes Away
By antiwebbite in forum AudioReplies: 3Last Post: 9th Jun 2010, 18:48 -
ConvertXToDVD 3.0 Surround Sound?
By chicken32 in forum Video ConversionReplies: 1Last Post: 3rd May 2008, 01:24 -
Make an xvid/avi from DVD but keep original ac3 surround sound?
By coolchris in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 07:35 -
5.1 Surround Sound on DVD
By Adhishyajnik in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 01:57
