I am having a problem merging the 5 VOB files for a movie into one VOB file, so I can play it back in Windows Media Player. The fifth one generates a "I/O Error 112" when it tries to merge it. I can use WinDVD player's playlist to play each of the 5 VOB's, but it "skips" between VOB's during playback, which is why I want to merge them. Any tips?
Are you using Win95/98/ME? If so, you would most likely be using FAT32 which has an upper limit of 4GB for filesizes. 5 VOB files (each one being 1 GB) would be too large, thus your problem.
Why do you want to keep such large files around to play video? Perhaps you should convert your VOBs into VCD or SVCD. Or else, if you have the original DVD around, just play your video off that.
Regards.
Michael Tam
w: Morsels of Evidence -
If you just plan to watch your RIP on your PC, then maybe making a DivX file would be a good idea (would take up MUCH less space).
I merge all the VOB files so I can then play it to record on a VHS tape. Yeah, I use FAT32, so that's the problem...I have Win2K, but use FAT32...does NTFS support 4GB+ files? I should be using it, I think. Thanks
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>I merge all the VOB files so I can then play it to record on a VHS tape. Yeah, I use FAT32, so that's the problem...I have Win2K, but use FAT32...does NTFS support 4GB+ files? I should be using it, I think. Thanks</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Okay, it makes sense then.
And yes, NTFS does support file sizes larger than 4GB.
Regards.
Michael Tam
Merging files
By drtbray in forum EditingReplies: 12Last Post: 13th Apr 2012, 17:08 -
Problem in merging splitted AVI files of a movie into one.
By nick2712 in forum Newbie / General discussionsReplies: 8Last Post: 2nd Oct 2010, 15:20 -
merging of .vob files
By jekkherg in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2008, 22:43 -
vob files problem
By warlock110 in forum Newbie / General discussionsReplies: 6Last Post: 23rd Mar 2008, 12:32 -
Problem with Vob files
By seven_deuce offsuit in forum Newbie / General discussionsReplies: 4Last Post: 26th Dec 2007, 11:04
