I made some .d2v and .wav files into Mpeg-2 (Super VCD [Non-Standard]) in TMPGEnc. I put it into VCDEasy and burned it onto a CDRW. On the computer it works fine. But in my DVD player (DV3000C) it doesnt play correctly.
Does anyone know what I can do to make the Mpeg-2 files work?
Thanks for the help.
If everything is infinite then nothing is definite.
Originally Posted by Thommers
BTW, did you check your machine in the DVD Players section? I did, it has trouble with SVCD's and with some media."Art is making something out of nothing and selling it." - Frank Zappa -
On the TV screen the picture is all distorted and jumpy. My DVD Player can work in SVCD mode with other mpeg2 files I dind't make from TMPGEnc. I need to know if there is something I need to do to the SVCD file after, or if there are options I should click before building it in TMPGEnc in order to make SVCD files work. VCD files work fine.
Do you know a good hosting site allowing batch download pictures and videos
By coody in forum ComputerReplies: 9Last Post: 10th May 2011, 12:52 -
EasyCAP only playing the video, not allowing me to save it
By denadel in forum Newbie / General discussionsReplies: 1Last Post: 10th Nov 2009, 08:48 -
allowing people streaming your videos, good or bad?
By lana2000 in forum Video Streaming DownloadingReplies: 10Last Post: 25th Apr 2009, 18:55 -
Google Sites Not allowing Embedded scripts.
By freebird73717 in forum Newbie / General discussionsReplies: 0Last Post: 2nd Sep 2008, 12:16
