I recently DL'd the Bit Torrent Client 3.2.1. After the computer said that I had sucessfully installed Bit Torrent, I went looking for fun.
However, every time I try to DL a file, it pops up an error that it could not connect to the server. Normally, I consider myself fairly knowledgable about computers, but this Bit Torrent thing has me stumpedCan anybody help me out?
When you want to download a bittorrent file you just click on the file link. A window will pop up asking where you want the file saved. When you choose a location bittorrent does the rest by downloading the appropriate file. The file must also be a BITTORRENT file. It will not download just any file.
I must be having an off day...
1) right click-->save file as
2) click file and start DL
errrrr....<stepping AWAY from the can of beer>
Thanks. -
I was getting horrible BitTorrent performance, then I went to the creators website and looked at the protocal info. After opening the range of 10 ports required and routeing them only to the machine that bit torrent is used on (for security reasons) I no longer get errors and my downloads are flying at insane speeds. If you use a software or hardware firewall I suggest checking into it.
Xvid4psp does not work on Windows 7 64 Bit version
By pectin232 in forum Video ConversionReplies: 0Last Post: 28th Nov 2010, 18:41 -
Windows Vista XP 64 bit Oh, my. Printer doesn't work!
By orfajackson in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2009, 23:27 -
MSADPCM doesn't work with Vista Home 32 bit
By programm in forum Video ConversionReplies: 1Last Post: 6th Mar 2009, 10:48 -
No capturing programs work on Vista (home premium 32-bit)...
By Rein Engel in forum Capturing and VCRReplies: 8Last Post: 28th Nov 2008, 18:42 -
Torrent searching engines and torrent softwares
By 1234567 in forum Off topicReplies: 7Last Post: 11th Sep 2008, 03:54
