Evening all, I have an Apex AD-800 which plays pretty well everything I toss in it except bin/cue files. I have burned these with both Nero and VCDEasy so I doubt the software is the problem. When I put the disc in it accepts it no problem, reports that it's SVCD and then when you'd expect a menu to pop up it just goes to a black screen with zeros in the time window. Pressing play, menu etc does nothing. Anything I can try or is this just not meant to be?? Thanks!
This is what you have to do:
Open VCD Gear and convert the cue/bin to mpeg, then open Nero and select SVCD and burn that mpeg.
I had the same problem with my old APEX. -
As I have stated many times... Apex's aren't really "that" good... especially if good PBC compatibility is important to you.
Regards.Michael Tam
w: Morsels of Evidence -
Yes but thankyou Apex for driving the price point down so that we can have quality product at sub $100 price points. Still no answer to your problem but I had to chime in.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
