My computer crashed the other day and i had to use the recovery disk on it. I have a laptop so i have a USB 2.0 card for my dvd writer and my HD. It only reads stuff on it at USB 1.1 speeds though, it takes over two hours to burn a dvd currently where before it took 1 hour. Can anybody shed some light on my issue.
PS> the drivers automatically install on windows XP, but i also installed them manually and still no change.
No i am using the cable that came with it, which is a 2.0 cable. Before my computer crashed it worked fine.
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 11:24 -
External USB drive that reads from Blu-ray AND HDDVD?
By Wyntertalamasca in forum Blu-ray RippingReplies: 1Last Post: 8th Mar 2010, 19:04 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 19:23 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 12:58
