Hi,
I got a little problem here. I hope someone can help me with this. I have a mpg video file of 790 MB on my computer and I want to burn it to 700 MB CD . Is it possible to do?
I am very new to this kind of things so it would be great if anyone can guide me.
Thanks in advance
Kutti,
You can fit 800Mbyte of video onto a standard 700Mbyte or 80Minute CD - it writes it without error correction (unlike 'data') which means you get another 100Mbyte to play with....
Just drag your MPG into Nero (using a VCD or SVCD template according to what type of MPG it is obviously) and it will fit just fine.
Cheers,
TeeeRex -
Yes, if burned as a VCD it will fit. If burned as a straight mpeg in data mode, it won't.
Reduce file size .
By pensioner in forum Newbie / General discussionsReplies: 4Last Post: 10th Dec 2010, 14:08 -
Reduce file size
By windranger in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2010, 09:18 -
Reduce AVi file size
By froggger in forum Newbie / General discussionsReplies: 7Last Post: 9th Feb 2009, 16:58 -
Reencoding to reduce the file size of an AVI (xvid) file
By DVantrease in forum Video ConversionReplies: 7Last Post: 10th Jan 2009, 20:56 -
How do I reduce file size using avidemux?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 27th Dec 2008, 22:41
