.m
Hello.
I think, every programme has it's problem, nothing is absolutely good. Vegas has it's problem too, in my case when I start Vegas, it anounce "DLL, error loading C:/Program~1~Sonic, Specified module could not be found". I've posted this post to Sonicfoundry Forum, and they answered me that, "It's no problem, re-install Vegas and the bug will be fixed". I tryed to uninstall-reinstall Vegas 4 many times, but nothing is fixed. Vegas still working with this problem, but in Render As > Mpeg-1&2, I CANNOT choose Custom Settings. I'm using Win XP. if you know how to fix it, please help me, thank you. -
You need to register the Main Concept MPEG plugin, then you can use custom features
Hi.
I knew it, Mpeg modul was registered. In my case, with Win 2000, Vegas works so well, without problem, I can set everything. But in Win XP it has this problem, so Vegas still works, convert to Mpeg-2 normally. I can't use custom settings, only use standard template. I'm using dual boot with Win XP/2000. -
i posted a fix for this here :Originally Posted by Tony08
http://www.dmnforums.com/cgi-bin/displaywwugpost.fcgi?forum=sonic-foundry_vegas&post=0...0321023204.htm -
Hi BJ_M.
I'm was busy for a week, so I don't know your reply. Thank you for a guide. I'll try it follow this guide and tell you later. Good bye.
