Can you overburn in VCDEasy? I made some menus and then put in the mpeg files and it came out to 802MB. I burned it on a 800MB CDRW and it seemed to come out fine from what little I saw (thought it said it was burning only 800MB). Does overburn automatically come on according to your CD writer (I have a Liteon that can overburn 82:59:59 I believe).
Thanks for the help.
If everything is infinite then nothing is definite.
Yes you can overburn in VCDEasy if your burner supports it. There's a checkbox you can click to enable it. I think it's in the Settings screen under the CDRDAO tab.
CogoSWSDS
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
DVD overburning. Is it possible?
By eroy in forum DVD & Blu-ray WritersReplies: 53Last Post: 6th Sep 2010, 16:57 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
