Post
I am about to buy the Canopus ADVC-100, to copy old VHS & Hi8 Camcorder stuff to DVD.
My Sony DVD Burner comes with Sonic's myDVD authoring software, should I try to get to grips with this or just buy ULead's Video Studio 7.0 which seems to come highly recommended.
I want software that gives the least hassle, but allows me to edit my Camcorder footage & add chapter menus etc. retaining all quality.
I see that myDVD goes on about being able to edit a previously written dvd in place without using the hard drive, is this OpenDvd ? and is it any use ?
My hard drive is 60GB.
What about Ulead's DVD Movie Factory 2 is this less sophisticated then Video Studio 7.0 ?
Also, do I need to use this TMPGEnc, I keep reading about ?
Ulead Video Studio 7 is very strong and simple for for editing and rendering. Movie Factory 2 is more for combineing and converting already completed video or captureing raw video or slidshows to a menu format for VCD/DVD. Edit the video in Video Studio 7 and save as a video file. Then import it to Movie Factory 2 with the other video to set up menus. Video Studio 7 will allow you to also capture and burn but movie factory is a simpler program for just captureing several files and burning.
Ulead video studio 8 help
By the big man in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jun 2009, 17:02 -
Ulead Video Studio 9 - colorspace
By Froddy1 in forum EditingReplies: 0Last Post: 2nd Feb 2009, 11:49 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 20:48 -
Does anyone use ULEAD Video Studio 10?? or any suggestions?
By cmlmich in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2007, 23:12 -
Ulead Video Studio 7 SE
By uricktam in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 12:14
