This is a NEW version
PluginPac FrameServer is a plugin which will allow NLEs to do FrameServing and AudioServing. FrameServing and AudioServing are the techniques used to transfer audio/video data from one application to another without doing a full fledged render and temporary files. PluginPac FrameServer is a plugin for NLEs enabling them to export their timeline audio/video data outside so that other applications can use the timeline directly as input.
Another use of the Frameserver/Audioserver is to serve audio/video data to an application that does not understand the source format. If you have an NLE that can open .MOV files and your MPEG encoder can read only .AVI input files, you can open the .MOV file in your NLE and use PluginPac FrameServer to serve the a/v data to your MPEG encoder. This way compatibility increases between applications.
Currently PluginPac FrameServer is available for the following software.
SonicFoundry Vegas (and earlier Vegas Video/VideoFactory versions).
Adobe Premiere.
Ulead MediaStudio Pro
http://www.debugmode.com/
http://www.debugmode.com/pluginpac/
THANK YOU Satish !! (and greets to DDog)![]()
Results 1 to 1 of 1
Microsoft SQL Server need in Vegas Pro 11?
By videobread in forum EditingReplies: 5Last Post: 11th Dec 2011, 22:11 -
Avid Studio vs. Sony Vegas Pro/Studio
By HoosierGuy in forum EditingReplies: 12Last Post: 8th Dec 2011, 20:06 -
Vegas Movie Studio Platinum Pro Pack vs Adobe Premiere Elements 8
By bowmah in forum EditingReplies: 6Last Post: 27th Jan 2010, 20:15 -
What is the difference between Vegas Pro and Vegas movie studio platinum
By jbitakis in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2009, 00:41 -
frame server doesn't work in Premiere CS4?
By ivanadit in forum EditingReplies: 0Last Post: 6th Jan 2009, 13:46
