  1. Hi!
    I just reencoded a DVD 90 Min. m2v movie with TmpgEnc to 5000Kbit m2v so it fits on a DVD-R with ac3 sound.
    It takes about 3 hours on a P4 2,4 Ghz Notebook .... speed is ok.
    But .... if I choose a Quicktime Movie from my Harddisk to encode to m2v TmpgEnc is veeeeery slow! It tells me that it will take about 32 Hours to convert!!!!!
    The Quicktime Movie:
    Mjpeg-A codec (2000 kb/s)
    768x576, 25 FPS interlaced
    Audio AIFF 44.1 Stereo, no Compression
    I choosed in TmpgEnc "not interlaced" and the regular DVD PAL settings by using the Wizard.
    Is it normal that a 120 Min .mov will take about 30 Hours to be converted to m2v?????????
    Please Help!
    Markus
  2. Are u youseing filter and was it interlace before, because that may account for some of that time still it sound long
  3. No, no filters.
    It's an interlaced source cause It's a captured movie from TV
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    quicktime IS slow conversion w/ several encoders - its decoding it twice really .
    32 hours is a bit extreme though , maybe let it go for a while and see if it decrease faster than that --
    you can open it in QT and save it out as something else (avi) which is faster (maybe - if you count the double conversion again - may be not any faster)
  5. YEAH ... got the solution!!!!!!
    I just changed the priority of the QT-PlugIn in the invironment settings to 1st!!! And now it takes about 5 Hours!!! In relation its the same speed as it took when converting a m2v source of 90 min in 3 Hours!
    So ... speed now is ok. !
    But thanks anyway!!!!
    Markus
