I have used nero for a while and I have not figured out how to add sound to the menu
I don't think Nero gives you that option. The only way to have dvd-like menus (sound/music, custom chapter images etc) is to use all in one commercial editing programs like Ulead VideoStudio but there are several drawbacks such as incompatible mpeg2 formats etc.
On the other hand, VCDEasy is very good, but significantly more complex when it comes to menu creation (for example you can create complex menus in Photoshop, convert to mpg in VCD easy, then edit the mpg to add music into the mpg file) but you need to look at one of the guides in the How To section for that.
Good luck.
JDC
Best way to add pop-up chapter menu?
By mikeveli20 in forum Authoring (Blu-ray)Replies: 2Last Post: 4th Oct 2011, 00:08 -
add menu without re-encoding
By mathmax in forum DVD RippingReplies: 2Last Post: 9th Jul 2010, 10:40 -
Program to add a menu to a DVD...
By Soccerman77 in forum Authoring (DVD)Replies: 1Last Post: 14th Sep 2008, 03:45 -
Add a language menu to a DVD
By hellbound in forum EditingReplies: 0Last Post: 6th Aug 2008, 10:01 -
Add menu to existing DVD?
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 2nd May 2008, 17:56
