Im trying to convert a divx file to a MPEG for vcd, this is the process i am going through: I open TMPGenc, open the video and audio sources (in this case i use the avi as the video, and an extracted WAV from Vdub as the audio source), then i load the VCD NTSC applet, and then i load the unlock option. I have used a bitrate calc to determine that 750KB/s is the quality i should use to fit the mpeg onto one cd, so in TPMGenc i changed the CBR to 750. Now the problem is when encoding is finished, the file size is 1.18 GB, which i found to be the size of the mpeg at the standard 1150 CBR. I have tried this several times with the same result. PLZ HELP, thnx.
I've ran into this problem before and it took me a couple days to figure it out... In the window where you set the CBR to 750, there should be a tab marked "System". Click that tab and change the setting to MPEG-1 (nonstandard). Then encode your AVI again. That should solve your problem.
CogoSWSDS -
ill try this thnx very much CogoSWSDS, nice to get a solution the same day i posted.
Also, TMPGEnc version 2.59 has a bug that always encodes at 1150 Kb/s. If anyone has that version, get the latest update.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thank you much, i changed the option in the system tab to nonstandard it i got the mpeg i wanted.
Hauppauge HD-PVR 1212 recording problem at CBR
By rds11 in forum Capturing and VCRReplies: 9Last Post: 10th Dec 2011, 16:12 -
By mail2tom in forum Capturing and VCRReplies: 5Last Post: 27th Aug 2011, 16:34 -
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 22:22 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 07:15 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 22:23
