I'm trying to get .avi/.wav (made in VD) files into an .mpg 1 file for a VCD and everying I press "start" a error comes up saying "write error occurred at adress 77f536f7 of module 'ntdll.dll at 0000000..." I tryed reinstalling but it just encoded the first 5 seconds of the movie then got a "write error occurred at adress 77f536f7 of module 'ntdll.dll at 00000018" How can I fix this?
I've been battling with read and write errors for the past week. Which is a real shame, cos TMPGEnc is a fine piece of software, when it works. I'm running out of ideas here. What's really frustrating for me is that the errors are completely random.... could try replacing my RAM I suppose....clutching at straws here... oh sorry I couldnt help!
Im sorry that i can't help either but im battling constant read errors at RANDOM spots too. I used to use many of the BETA 12 versions of TMPGEnc to make VCD's, but i havent used it for a very long time, and now i download plus 2.510 and the thing comes up with constant BUGS.
I had this happen to me a couple of times a few months ago and was told that the files were XVID files. If you have the fourcc program you would be able to check this out and re-convert to DIVX if need be. After I did this everything worked okay for me.
Beneath every smile is a wicked grin. ;)
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 11:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
