Can anyone suggest some reasons why the VCD created using the adpatech Easy CD Creator 5 cannot play in my VCD player?
there isn't anything wrong with the mpeg file... the burn went fine... can play dat file using windows media... but it still cannot play using my vcd player....
why why???
Results 1 to 11 of 11
TRY USING THE NEW NERO INSTEAD OF ADAPTEC
IVE USED NERO SINCE I STARTED WAY BACK...NEVER HAD ANY PROBLEMS..NEVER TRIED ADAPTEC THOUGH -
Dont Know whats wrong no definite answers ive use easy cd 5 a couple of times even done a menu one of the time, Maybe just a very very slight incompatability with your writer
At the moment im using GOdvd it uses the nti writing engine its excellent you can do scene selection menu with it well worth the doe....... But sorry cant be more help -
I started with Adaptec & tried to be loyal. Started with 4, bought 5 & with >$150 invested I have mostly frustration.
Creating VCDs is a pain. No SVCD support - they won't even mention if they ever will. Menus are confusing & limited. I like to add an autorun.inf file to play VCDs in media player for relatives w/o DVD. I was able to use the bibliography entry to add this file and abstract to put the play.asx file to script the MPGs. With version 5 putting files in the fields causes a runtime error which they refuse to admit. The short customer service period is totally useless. No other company survives giving this poor service quality - heck Microsoft looks like a saint in support in comparison.
Final straw was when they cut back their online support staff & played games with paying others.
Wait for some new product coming out supposed to do DVDs also or better yet shop around for software that works. For me now it is VCDimager with the latest TSCV GUI. Free & it works.
PS. They seem to name the MPGs MUSIC01.MPG, MUSIC02.MPG ..... which is nonstandard to using AVSEQ01.MPG, AVSEQ02.MPG . . .
<font size=-1>[ This Message was edited by: kitty on 2001-09-16 16:03:34 ]</font> -
I had kinda of the same problem. I have EZCD 5 Platinum made alot of VCD's then all of a sudden something changed, couldn't find what so I to Nero it's all fine then.(LAST RESORT) So I Fdisked the system and started over EZCD 5 works fine now. You might want to try uninstalling 5 and reinstall 4 then 5.
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>PS. They seem to name the MPGs MUSIC01.MPG, MUSIC02.MPG ..... which is nonstandard to using AVSEQ01.MPG, AVSEQ02.MPG . . .</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
This isn't actually important. Both are allowed.
Regards.
Michael Tam
w: Morsels of Evidence -
Thanks guys for your help and comments...
gimp, I dun have Adaptec 4 can try your suggestion...
Think i will try Nero (though it's looks complicated to use...) or VCD imager as suggested Bigthree2001 and kitty..
thanks.. =)
I will still use adpatec for music cds and data files... works just fine and simple... that's why i like it...
btw, if you are using Windows XP RC version... do not install CD Direct... it is incompatible... had lotsa problem... think Roxio.com finally put up an article for window xp users...
thanks again...
if anyone figure anything out, pls post and let me know... =) -
Have you tried the obvious, a different brand of CDR ?
ECDC, makes perfect VCD's no problems at all. Just try a different brand of cdr. -
EZCD Creator puts the DAT file in the wrong DIR.
I had the same problem.
Nero and other softwarez, put it in the right DIR, so DVD players can read it.
This has only happened after I install EZCD Creator 5 -
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>EZCD Creator puts the DAT file in the wrong DIR.
This has only happened after I install EZCD Creator 5</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
EZ CD Creator only does this if there is something significantly wrong with your MPEG. Otherwise, it places the mpeg in the normal folder.
Regards.
Michael Tam
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 15:26 -
Easy DVD Creator by Ether Software
By DW49 in forum Authoring (DVD)Replies: 4Last Post: 30th Dec 2007, 15:33 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 16:27 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 13:10 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 16:27
