  1. Hi all,
    I'm using the MainConcept MPEG Encoder and when ever a set it encoding the MPEG it upside down and reversed. The picture quailty and sound are fine just the image is the wrong way round. I've reinstalled the software a couple of times and it doesn't fix it.
    Can anyone help?
    Cheers MKay
  2. I had this problem once converting a file I downloaded and it would always be upside down I was using tried it a few times always the same prob. Downloaded the file again and it was okay.
    Is the file that you are using one you have created ?, or a downloaded one ?
    If it's wet, drink it
    My DVD Collection
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Some codec or filter is rendering your source the wrong way - and this is what MC sees. Try changing the settings (flip/invert) for the codec(s)/filter(s) involved.
    /Mats
  4. The file is one I have downloaded and I know that it isn't the problem after hours of testing last night. The codec is a good idea though. How do you change the flip/invert setting for the codec?
  5. Cheers guy it turned out to be to codec. Uninstalling it and reinstalling it fixed it.
