Hi !
I just bought the sony dvd burner and i have a question ?
My doubt is because i don't want to lock the dvd burner in one especific region... I wanna be able to copy and burn any dvd (different regions) without the worry about this issue.
If i burn Region 4 DVD's into DVD-R does my burner will be setup to region 4?
FYI I have a TOSHIBA SD-M1612 as a DVD-ROM (region free firmware hacked)
Can somebody explain me how it works ?
Also
How can i make my burner a region free ?
hgtvg
If you create a DVD it will be region free.
If you rip a DVD in your toshiba, make sure you make it region free before burning.
Why burn region 4 DVD when you can burn them region free? This way you will not have a region locked Sony burner. -
Thanks for your reply but that's not what i meant...
My doubt is If i make an on the fly copy of a dvd disk does my burner will check the region of the disk ? and... because of that count as a region change ? .
also if i rip to my hd and re authoring with some software tool does my new dvd burn disc will keep the original region code or it will be region free disc ?
Last question... How do i take it off the region info from the dvd when i rip to my hd ?
Thanks in advance...
hgtvg -
oh one more thing...
i don't want to burn a region 4 discs... I just want to have sure that if i make an on the fly copy my burner will not check the region code and change it
hgtvg
sony dvd rw dru-190a problem
By videodude1966 in forum DVD & Blu-ray WritersReplies: 2Last Post: 17th Apr 2010, 04:53 -
Problem with Sony DVD RW DRU-830A
By VOD0708 in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Jan 2010, 15:43 -
where to get original Sony DRu-820a DVD Firmware
By scustalow in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jun 2007, 12:00 -
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41 -
Sony DRU-820A DVD Drive suddenly burning slow
By progrocktv in forum DVD & Blu-ray WritersReplies: 3Last Post: 24th May 2007, 22:55
