I am learning about multimedia. I want my source to be the best with the highest resolution. I just watched my first DVD and it blew away my satellite. Is cable any better then satellite or do I need to use rented DVDs as a source?
dvd will be better then cable and sat...
the next best thing would be a high def source. -
What other sources are there? Where can I get a high definition source?
Thanks much -
hdtv
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
DSS (digital satellite tv) is either 704x480, 544x480, or 480x480 depending on your provider. DVD can be up to 720x480, but most homemade discs should probably be 352x480. HDTV is much higher, and has variant resolutions.
Your tv cannot really see past 352x480 anyway. Only HDTV can go past that, and its not mainstream yet, nor is it standardized.I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
I watch using my 24" Sony monitor so the monitor presents no limitation. It looks like until HDTV is available widely then DVDs are the way to go. They can be rented or bought used fairly cheap.
neo
Get video footage from Cable/Satellite/TV to Laptop?
By fazsnatch in forum Newbie / General discussionsReplies: 1Last Post: 4th Oct 2011, 10:01 -
How do satellite & cable company's play HD movies
By neworldman in forum Off topicReplies: 6Last Post: 5th Dec 2010, 14:18 -
How can I get 1080 resolution from PC-HDTV without HDMI cable?
By leopardx in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2009, 08:41 -
Cable tv shows through when I watch satellite
By szalaikornel in forum DVB / IPTVReplies: 0Last Post: 19th Feb 2009, 16:09 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14
