OK, I have used DVDShrink several times, and it makes great copies. Now I am noticing that it shrinks the copies I am making more than they have to be shrunk.
Example: I will set up a DVD and find that level 1 will copy at a total of 4.20GB (about 14% loss of quality). This is after I re-author and re-encode, remove audio, etc. However, when I begin the encoding process, the program tells me that it is removing appx. 26%. When it finishes, I check the files and realize that there is only 3.85GB of information there. What happened to the difference? Am I missing something?
Ron
Come to think of it, I have noticed that as well. I wonder if it always does a little more compression than necessary. It may be handy if you are only a few meg over 4.38.
Has anyone else had any problems? I have had a few:
Star Wars Attack of the clones, it was happily processing along and when it came to the final part it crashed. I tried it a few time, same result.
Independece Day - The program crashes before you can finish selections.
Cast Away - No Audio. I have tried several permutations.
Gotta say that I LOVE the program though. The edit feature is great. Super fast, good quality. A few quicks but what program out there doesn't? -
On occasions it hasn't reduced it enough for me
, though I ain't complaining but thought I'd add the info
only by around 0.03Gb though but enough to go over 4.37GB
question about dvd shrink
By marlo in forum Authoring (DVD)Replies: 5Last Post: 29th Aug 2010, 04:22 -
Hello I'm New & I Have A Question About DVD Shrink 3.2
By taffy1967 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2010, 04:28 -
question about DVD Shrink
By Bamahusker in forum DVD RippingReplies: 7Last Post: 1st Mar 2010, 20:48 -
DVD Shrink compression method question
By SCDVD in forum Newbie / General discussionsReplies: 5Last Post: 14th Jan 2009, 12:42 -
question regarding analyze in DVD Shrink
By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 8th Jul 2007, 08:31
