I have a Cendyne CDICD00106, which is exactly the same as the Pioneer DVR-104 DVD-R/-RW drive. It is properly recognized during boot up in dos and in the bios, and even immediately after I boot up into windows. However, the minute I try to use the drive I have problems, and if I go into my computer the drive is no longer properly recognized, but recognized as a regular cd-rom drive. The drive will not play a commercial DVD movie. Also, I cannot burn with the drive. In windows, or in Nero. Both places give errors saying that the disk I am trying to write to is either not a cd-r, or is full. I cannot burn cds nor dvds. I cannot even read cds on the drive.
I have updated to firmware to 1.33, and then to 1.4, still no success. I have updated the ASPI drivers, and tried force aspi. I have made sure the drive is the master, and updated Nero to the latest version. I have also checked windows update. I am running XP. It seems to me that it may be a defective drive. Sorry about the long post but I just wanted to let you know what I've tried! Thanks for the help.
Have you tried checking rather the device is using DMA or PIO mode? Also test the drive while its the ONLY device on the IDE chain its using. If that doesn't work try to make sure you have a good IDE cable, and failing that I'd call Cendyne.
How do I check if the device is in DMA or PIo mode? I did try a different IDE cable and the drive is the only device on the cable. I guess if the DMA check doesn't work I'll call Cendyne. I posted a message on their help forum and they suggested changing Nero settings which have resulted in no success. Thanks for the help.
Pioneer DVR 520-H does not recognize disc
By Steve_Rbts in forum DVD & Blu-ray RecordersReplies: 0Last Post: 13th Sep 2010, 00:35 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
Pioneer DVR-520H: firmwares and service disks ...
By donglejack in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Jul 2007, 12:14
