ok i was using TMPGenc and have no prob till now........now when ever i convert from avi files to vcd the sound is always slower than the video any ideas???i didnt change anything at all thanks
Two bits of advice. Check the AVI file and make sure it's not whacked out . You can try to use another encoder (2lame) to encode the audio. Is it off by the same amount the whole movie or does it get worse and worse?
sometimes the same amount and sometimes get worse ok what i usually do is save the audio to wave files from vituraldub than convert with the video in
TMPGenc and i got no prob with it at all till today.....and i cant find any reasons ..............
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 08:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
