Hi,
I was just wondering if anybody bought a Pioneer DVD-R model AO4 or AO5 recently? I was wondering if it worked perfectly under OSX.2 and iDVD 3. Also if it runs well with DVD Studio pro 1.5
Was installation hard? and what are your general comments, ups and downs.
I was looking for a great DVD burner that will fit my needs before investing all that money.
Thankyou very much!
Kev
Kepp on Rocking in the free world
I'm a PC user but Apple use's Pioneer drive's in all there MAC's I think Apple is useing the New Sony Drive that burn's both format's DVD-R and DVD+R the sony drive is junk pioneer I would say make's the best drive. Sorry I can not help you with more info
The Pioneer Dvdr 105 is the OEM drive with new macs. I think the A05 is the same model, right?
I have seen on macfixit many people very satisfied with the A05 internal as far as iTunes, iDvd and iMovie compatability.
I have a 105 and it works great with everything. Mine is in a LaCie case so I cannot use iDvd (must be an internal fo that), but everything else is good (studio pro 1.5 too).
To double check, see xlr8yourmac.com, they have an pretty good dvdr/cdr drive compatability section that may answer your questions.
As far as I know, dvd+r is not supported by OSX. This seems to vary from model to model though, some iMacs can read it, but none that I know of can burn it (if you find a way let me know).
Hope that helps
M -
I added a Pioneer 105 (actually a Cendyne 105 - same thing) to my new G4 867dp when I got it and so far I have used it with OS 10.2.4 & 10.2.5. I have burned iMovie 2&3 movies using iDVD 2&3, made back-ups with DVD2one, and backed up data all with out any probs. The only coasters (3 out of 20+) were my fault. Installation is a piece of cake and I haven't seen a downside yet.
Matt
Originally Posted by kpott -
I purchased a CenDyne AO5 drive for fairly cheaply from OfficeMax, the CenDyne is a Pioneer DVR-105 in actuallity. I put it in a B&W G3 which has a G4 upgrade card. It works good, but i have noticed that in my computer it does seem to get very warm. (By the way, my computer originally shipped with a DVD-ROM drive and has a hardware decoder daughter card on my video card, my hardware based Apple DVD player still works in OS9, and the lastest software only player works fine in 10.2.X.)
Live feed into a dvd recorder
By slaak in forum Video Streaming DownloadingReplies: 26Last Post: 26th Sep 2013, 04:47 -
PC live feed - how-to and hardware
By don.johnson in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 21:53 -
Feed the world
By guns1inger in forum Off topicReplies: 0Last Post: 26th Nov 2007, 02:44 -
Replacing Back-up Lithium Battery for Pioneer 520H
By dvp7 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 24th Oct 2007, 01:35 -
Pioneer XV-DV313 will only play back up copies of dvd's, not originals?
By moults in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th Aug 2007, 15:17
