how do you convert dat files to mpg using dat2mpg or is there another program that will do this?
<font size=-1>[ This Message was edited by: gadget on 2001-09-16 10:32:18 ]</font>
hmm...vcdgear? U can download it through the sidebar
OTHER -> Tools
<font size=-1>[ This Message was edited by: Enocodet on 2001-09-16 11:35:50 ]</font> -
Or you can just right click and rename it to whatever you want .mpg.
I downloaded vcdgear and it works great. converted some dat files from original vcd karaokes to mpg and used goldwave to change the pitch. now i can customize my own vcd karaoke from my collection of karaokes. thanks to you guys.
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>Or you can just right click and rename it to whatever you want .mpg</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
No. You should never do this. The DAT file has a few things added to the original MPEG stream. It is questionable whether or not programs handling the MPEG would be able to work this out.
You should use VCDGear to convert the DAT back to an ordinary MPEG. It takes no longer than copying it over to the HDD.
Regards.
Michael Tam
w: Morsels of Evidence
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 10:25 -
DAT/MPG to VOB/MKV?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 30th Jan 2011, 05:21 -
convert DAT TO avi
By skorpinok in forum Video ConversionReplies: 1Last Post: 27th Nov 2010, 03:53 -
Algorithm convert DAT to AVI
By Nemo_wf in forum Video ConversionReplies: 5Last Post: 5th May 2010, 03:18
