I have a VOB file I ripped from a home authored DVD... I set decrypter to merge the VOB files from the DVD and create one large file on the hard drive.
Within that DVD there were 19 titlesets... What i would like to do is have all these title sets merged and create one m2v file and 1 ac3 file from the VOB... I tried Tmpgenc and it seemed to work ok but whenever i play the m2v it misreads the length of the file as being the length of the first titleset only...
I also tried VOB Edit to Demux and i got the same thing, it thinks the entire 3.5 gig m2v is 30 seconds long. Same thing also when i import it into maestro..
Is there anyway i can demux and get the m2v file to play with the correct length ? Or is there anyway i can change the m2v file i already have to play correctly ?
Any help is most appreciated..
I hope i have the terminology correct... Im not 100% sure titlesets is the correct term....IFO reads the VOB as having 19 PGC's
