L.S.
Ffmpegx opens with the default mpeg4(mencoder) option enabled. When i press encode the terminal states it is a xvid encoding and it finishes the encoding. When i open the file in mplayer, the info button tells me it's a xvid file too. And i want it to be a divx file!
When i use the xvid option in ffmpegx, the terminal tries to encode the movie to divx, but the encoding stops after half a second, leaving a 0kb file.
Furthermore the audio-sampling rate is stuck to 48khz, whatever i choose in the audio-tab in ffmpegx.
I trashed the ffmpegx prefs, and used different versions of ffmpegx.( a,b,...k) and the problem wont go away.
Can anyone tell me what to do now?
