When I try to open a video file in Virtual Dub it says I need a Video For Windows (VWF) codec. I have lots of codecs installed but I don't know what I should do about this one. Any help is appreciated. Thx
Open your AVI file using the 'AVICodec' program (see TOOLS section on this site) - it should tell you what codec it needs.
I believe the file you are using may be a renamed .asf file or maybe a partial download. I have gotten this problem occaisonally.
The simplest solution I could resolve is to
1. run TMPGEnc, select File menu, new project
2. click on video source browse button and select the AVI file. You may need to adjust the VFAPI plugins for the file to open
3. Select File, Output to File, AVI file. You should select a compressor for the video (say HUFFYUV)
4. Save it
You now have a valid AVI that VirtualDub (or anything) can open.
Note: this method works with just about anything Media Player can play (ASF, WMV etc)
virtual dub não abre arquivos cokm codec xvid
By sandroguchilo in forum AudioReplies: 3Last Post: 14th Dec 2010, 16:43 -
ffdshow codec not showing up in Virtual Dub
By uglijimus in forum Video ConversionReplies: 2Last Post: 8th Mar 2010, 15:12 -
virtual dub xvid codec encoding w/o profile
By caner12 in forum EditingReplies: 7Last Post: 5th Jul 2009, 12:08 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 17:47 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36
