I am backing up this movie and its a DVD-5 so i used Decrypter for everything (creating the image and burning it) and when i put it into my standalone Sony DVP-NC655P player it says something like
Now ive have done many DVD's this way w/o any problems, and i checked the disc, the came straight out of the burner and into the player, not a thing on it!Error:13:60: The Disc is dirty.
Do i need some hack or something?
ANY help would be very appreciated...
Justin
:agree: -
i just tried it on another sony dvd player (not sure what the model # is) and got the same message
Justin
:agree: -
only time i had that was when i used a cheap media.
which media have you used ?
thingimijig. -
someone w/ a sony dvd player or has backed up this movie has to be around this forum someware!
Justin
:agree: -
I have backed up this movie. I used a Hp dvd+r 300i with verbatim disks. I get the same message, but if you hit play after the message it should play like normal. One thing you could try that I haven't tried is use dvd decrypter under file mode extract all files then use IC to burn onto a disk.
thanks, i'll try pushing play and if that dosnt work i'll use IC7
Justin
:agree: -
I backed up the movie and it plays just fine on my standalone DVD player, a sony DVP-NS300. I used DVD Dycrypter version 3.1.4 or something like that, an older version that was current at the time. I burned it using nero 5.5(with the upgrade) on my Philips DVD+RW 208. The only difference I see is that I am using DVD+RW. Mine works fine in my sony player and also on friends JVC DVD player.
Office 2007 can't be uninstalled
By ukb007 in forum ComputerReplies: 3Last Post: 15th May 2011, 10:51 -
The Office (UK)
By tgpo in forum Off topicReplies: 1Last Post: 6th Sep 2009, 23:10 -
Mass conversion of Office 2003 files to Office 2007?
By Xylob the Destroyer in forum ComputerReplies: 8Last Post: 17th Jun 2008, 01:06 -
Office XP Pro?
By videobread in forum ComputerReplies: 5Last Post: 8th Apr 2008, 14:11 -
Is VCD/DVD disc space limited by time, or space?
By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 20:55
