i bought a dvd player out of safeway today (United Kingdom), its a prism, neva herd of it tho it plays everything apart from different region discs, does neone have a hack for it, it doesnt have a model number or nething
thank you
thanx m8 but i got it
1. Press the Open/Close button on your remote control to open the drive tray
2. Press the Setup button on your remote control
3. Using your remote control, highlight but do not select the Exit Setup option in the menu
4. Press the buttons 1, 3, 6 and 9 on your remote control, in order, one at a time
5. Press the Left button on your remote control, three times, in succession
6. Press the Right button on your remote control
7. Select the new Version option from the menu
8. You will now be able to change the value to 1 for Region 1, 2 for Region 2, and so on, or 0 for multi-region playback
just incase neone needs it
DVD Region 1 Hack Needed!
By poisonivy4 in forum DVD RippingReplies: 2Last Post: 14th Jun 2010, 11:43 -
Samsung dvd-vr350 hack needed
By david432111 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 12th Nov 2008, 08:20 -
new hack for samsung DVD-P181 needed
By indigogirl1200 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 9th Nov 2008, 20:58 -
Hack needed
By chisholmh1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 31st Dec 2007, 11:32 -
Durabrand PDV-709 (Portable DVD Player) Hack Code needed
By Caribsurfer in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Dec 2007, 10:49
