I have the AIW Radeon and updated my drivers. Now anything I capture won't play in either Windows Media player or ATI file player. Yet I can view it in Ulead MediaStudio and render it to a final movie file. But I cannot then view that rendered file in either Media Player or ATI File Player.
I tried uninstalling then reinstalling from my ATI disks, but no luck. Still won't play. I can play other videos in both players, just not captured stuff.
Can anyone help me out with this one??
Thanks!
raiderray
A little more info please .... what format are you capturing too ??
or does capture format not make a differance
Guido -
Sure, I'm capturing straight to SVCD 480X480 MPEG format. I haven't had any problems viewing previous captures till upgrading my drivers.
I also downladed Virtual Dub recently, could that have anything to do with it?
Raiderray -
I suspect something may have gotten messed up with your MPEG-2 codec (SVCD uses MPEG-2 format.) Try capturing to MPEG-1 format and see if that will play. If the MPEG-1 format file plays, that narrows it down further. Providing the MPEG-1 file plays, I suggest reloading your DVD player software. Usually when a DVD player software is loaded it installs an MPEG-2 codec (required for DVDs also.)
If you installed the "normal" version of VirtualDub it shouldn't have caused any problems with MPEGs as it captures to avi format. -
Well, I just tried reinstalling the DVD software. While I can capture and play MPEG 1 files, I still can't view MPEG 2 video that I capture.
Help!
Raiderray
DVD won't play
By BLSAMPLES in forum Newbie / General discussionsReplies: 5Last Post: 24th Sep 2009, 23:20 -
advice on hardware to play HDTV captures
By halsboss in forum DVD & Blu-ray PlayersReplies: 6Last Post: 29th Aug 2009, 08:07 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
Ati AIW won't remember video resolution
By crimzind in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2007, 17:07 -
How do i play XVID and DIVX files with my Vid-out (Radeon 9200) on my TV
By azman666 in forum Software PlayingReplies: 2Last Post: 13th Jun 2007, 23:09
