I was in for a surprise today. I placed an order for a DMR-HS2 yesterday and expected to receive it in a few days. For some reason I checked to see what the status of the order is and they said it's been discontinued! Obviously I was shocked. I found a few mail order places that are out of stock but I figured it's selling fast and new. One other did say discontinued so is that true? If so, how come?
I don't know if it's been discontinued. Why would they do that? It's their latest dvd recorder. I can understand if they discontinued their older models though. Anyway I have noticed that prices on this model have actually gone UP if you go check pricegrabber
Hello
Not to worry it is a good thing.
Panasonic is releasing a replacement called the DMR-E80H which is pretty much the same unit (though I think it lacks a FireWire input) except it has a built-in 80GB HDD plus it will not have the dreaded "black-level" bug.
This puppy is expected to hit the market in late July or early August 2003 at an estimated mail-order price of somewhere between $600 to $700
Sometime later this year Panasonic has another model due with a built-in 120GB HDD that will have FireWire inputs. This model is not due until several months after the DMR-E80H but will most likely be out in time for the end-of-the-year Holiday shopping spree.
Panasonic Canada told me both models were due to be released in August. You might try to email Panasonic USA for an update...
Instead of increasing the hard drive space they should concentrate on maybe including a tivo like program guide.
The reason the transfer from HDD to DVD-R is so slow (real time) is that it has to re-encode when doing the transfer. Therefore if you intend to record to the HDD first with the idea of THEN putting it on DVD-R you should use the XP speed (the best recording mode) so the quality loss when going from the HDD to the DVD-R is not so noticeable. To clarify ... record to the HDD only in XP mode then when you record to the DVD-R you can drop it down to SP or whatever so that your program "fits" on a DVD-R disc.Originally Posted by dafoe
HOWEVER ...
Please note that HDD to DVD-RAM transfer is faster than real time as it does not re-encode AS LONG AS you record to the HDD at the speed you record to the DVD-RAM
So in that case if you record XP to the HDD but then SP to the DVD-RAM it will re-encode it. But if you record SP to the HDD and then SP to the DVD-RAM there is no re-encoding being done.
Wow!
I've noticed a slight quality loss when transferring from HD to DVDR but I didn't realize that it was actually re-encoding.
I would love to record everything in XP mode to the HD but that would only be aprx 8 hours worth of shows. I am collecting 5-6 shows right now so my HD would fill up very quickly.
Besides, most of the stuff I collect is from the 80s, 90s or earlier so the original quality wasn't spectacular anyway. Definitely food for thought though.
Thanks for the info.
Panasonic DMR-HS2 power on failure
By rmhartman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Feb 2012, 15:19 -
Panasonic DMR HS2 (Setup Mode?)
By philo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2009, 13:14 -
Panasonic DMR-HS2 - shuts down when I try to record
By donmeyer2 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Sep 2008, 23:35 -
Problem with Panasonic DMR-HS2
By rmhartman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2008, 16:07 -
Help ! - I can't get my Panasonic DMR-HS2 to open - crazy machine......
By agent31 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 13th Sep 2007, 03:12
