I see a lot of people using this with InstantCopy and I just want to know what the big deal was.
Thanks mang
Instant Copy doesn't know how to handle when you uncheck titles of the DVD Structure. So if you use the reg hack for IC -- chances are that the IFOs are messed up. So to fix this, people are using DVDToolbox to strip whatever they want from the DVD and feed that to IC. This way, IC won't mess up the IFO files.
dhluke -
exactly ..use either dvdtoolbox or dvdshrink to strip the main movie and then feed it to IC. My fault for recommending to do it by just unchecking IC. Guess I got to excited when IC first came out and all. When I redo my IC guide I'll only recommend that way and if you do want 1:1 rather than Main Movie Only then just reduce extras way down in IC.
Any product similar to the AV Toolbox AP-411 lip-sync corrector?
By svejkovat in forum AudioReplies: 3Last Post: 5th Feb 2012, 12:29 -
How do you automate DVRMS Toolbox
By Datahead in forum Media Center PC / MediaCentersReplies: 0Last Post: 3rd Nov 2007, 09:55 -
Free copy of AVI Toolbox today only (8-23-07)
By Solarjetman in forum Newbie / General discussionsReplies: 0Last Post: 23rd Aug 2007, 11:58 -
AV Toolbox AVT-8710?
By hip_school_preppie in forum Capturing and VCRReplies: 4Last Post: 30th May 2007, 18:43
