Hello anybody,
I've been ripping with TMPGenc for a while, and its great but it just takes bloody ages. I have a Real magic hollywood+ dvd card and Win TV pci card. I struck on the idea to bung the s-video cable between the two cards and try and capture in real time in ravisent cineplayer or powervcr. I've had a couple of attempts in both but i'm struggling. In cineplayer DVR it works but is quite stuttery on a setting which works fine on my computer setup when capturing direct from the tv. On powervcr it captures in B+W but doesn't seem to be that stuttery at all. So basically, has anyone else used this kind of method sucessfully? and can anyone give me some pointers to a good setup or the best capturing program to use? Does it make a difference if i capture direct from the dvd or is it better to capture from ripped .vob file? HELP PLEASE!!!!
If you choose the Hollywood/WinTV Card -> Realtime method, your quality result would not be as great as if you went the (very long) DVDRip->TMPGEnc method. Just letting you know... =|
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 02:12 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 22:51 -
WIN DVD 9 plus Blu - Ray
By orfajackson in forum Newbie / General discussionsReplies: 3Last Post: 23rd May 2009, 16:48 -
Win XP - How to reset the DVD/CD burner?
By coody in forum ComputerReplies: 1Last Post: 7th Feb 2009, 23:15 -
Is DVD-RB compatible with Win Vista???
By Eternal7331 in forum DVD RippingReplies: 3Last Post: 11th Oct 2007, 00:31
