i dont know if i am the first person to try this (i really severely doubt that i am) And i've actually known about this for a little while, but i figured just in case there were people who didnt realize it (which im sure there are) SVCD (or maybe just XSVCD) is NOT constrained to being 480x480. Now i just want to say that im assuming its most likely just XSVCD at that point because SVCD is probably very strict and specific whereas XSVCD is more versatile.. and im not sure if this works on ALL dvd players, but its worked on my PS2 and all my pioneers and from the way things seem im PRETTY sure that any DVD player that accepts XSVCD will accept it in this format. Whats nice about this "discovery" (again i apologize if someone covered this before and i missed it) is you can then use Quicktime MPEG-2 encoder to make SVCD files.. since the mpeg-2 export in quicktime is the fastest ENCODER (remeber encoder, this strikes dvd2one out of the list b/c it doesnt re-encode) it makes the process of encoding for SVCd a lot quicker. You can encode the video to whatever bitrate you desire with the mpeg-2 export and then mux that with mp2 audio with the sampling rate of 44100 as an SVCD in mplex and vcdimager will accept it, and cdrdao will burn it as a SVCD with no problem.. they display the same and work the same in any player i've test them in. Just thought i'd share that idea since im sure many of you use quicktime mpeg-2 export for a variety of things, but im not certain if anyone has ever used it to make an XSVCD. Another nice thing about doing it this way if you want that video to go from an SVCD to a dvd all you need to do is re-encode the audio to 48000 and your ready to go....
please dont ask any questions about mpeg-2 transcoding in quicktime because i dont wanna answer a question that has definitely been addressed b4, a LOT of posts on this forum cover the mpeg-2 transcoding method in QT, im sure its on some tutorial websites as well.
Results 1 to 1 of 1
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind.
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
High-Resolution VCD/SVCD Stills on the UNIX Command Line
By sterno in forum User guidesReplies: 7Last Post: 20th May 2009, 12:16 -
PAL SVCD - Optimal resolution for preserved aspect ratio?
By Gew in forum Authoring (VCD/SVCD)Replies: 7Last Post: 27th Feb 2009, 14:25 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
An Interesting Problem
By Randalliser in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 9th Jun 2008, 19:15
