When I download that bitsetting program and try to run it with my TDK DVD burner that burns +R/RW media it says I have a first generation DVD burner that will not allow me to change the booktype. Is this correct I thought that I would be able to use this bitsetting program. I do not get the option in Nero 5.5.10.20a either do I have something set up wrong?
Thanks for any help.
Forgot to mention that the TDK burner I have is supposed to be a next generation burner. I am sure that it is not a first generation burner.
I believe this is a rebadged NEC burner. You cannot use the bitsetting utility on either Sony and NEC burners.
Bitsetting compatibility
By davidprosser in forum Authoring (DVD)Replies: 2Last Post: 12th Jan 2011, 14:39 -
Does a Samsung TS-H653N support bitsetting?
By raryke in forum DVD & Blu-ray WritersReplies: 4Last Post: 26th May 2009, 11:54 -
Change bitsetting on DVD Duplicators?
By wetcamelfood in forum Newbie / General discussionsReplies: 7Last Post: 14th Sep 2008, 14:58 -
Enabling Bitsetting on Pioneer DVR 215
By here2rock in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Aug 2008, 05:29 -
Any Pioneer burners do bitsetting?
By kenmo in forum DVD & Blu-ray WritersReplies: 62Last Post: 7th Jul 2008, 23:33
