Im gonna write this fastguide hoping somebody can use this so you wont loose time like i did....time is money so lets dive in to it,will we...
on a clean computer(without codecs installed) with divx5.04 installed and the vorbis ogg filter 0.9.9.x you should be able to watch it in your favourite player.
Get virtualdubmod and the required dlls ....
get mp3alllconverter (ogg to wav)
ok open virtualdubmod and open video file your file
virtualdubmod will then parse the ogg audio.
When its done go to ogg inputs select your file there and mux ...
save it as your audiofile.ogg
After a while when i finished open your converter and convert ogg to wav
Put the twos in tmpgenc youll now how and if not there are any guides for it.
You should have a perfect muvie.mpg
luck![]()
Results 1 to 1 of 1
Problem converting MKV files with a DTS audio track to DivX
By ryebeena in forum Newbie / General discussionsReplies: 2Last Post: 28th Nov 2009, 04:31 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35 -
Audio synch issues when converting to XviD or DivX
By baduncan in forum Video ConversionReplies: 3Last Post: 15th Dec 2007, 13:25 -
Converting Video/Audio TS folders to DivX etc.
By supermac in forum MacReplies: 7Last Post: 18th Jul 2007, 08:58
