I am going to use 2pass VBR for my conversions and im wondering that the best settings for that are?
Im am going to put the movies into 2CDs.
What should the average, maximum and minimum bitrate be?
And where can I find a bitrate calculator for the average bitrate?
Should I use the Highest Quality mode in "Motion Search Precision" ?
My DVD player does not like the bitrate to be too high or too low, so my minimum is 400 min. (padding enabled) and 2500 max. Your min. setting can be lower to free up more bits for higher action scenes, as well as a higher max. to give better quality. You may need to do some testing if you want to push the limits. I set my average to fill the disk, but I don't like going below 1700 as I find quality suffers. I'll use 3 disks instead.
I use High Quality mode, not highest. The opinions are that the highest mode greatly increases encoding time without improving quality much. Test and compare.
If you're using TMPGEnc (sounds like it) then the Wizard will let you set the average bitrate to fill the disk (I go to 99%). If you need a bitrate calculator, they're in the Tools section.
Good luck!
8)
"Art is making something out of nothing and selling it." - Frank Zappa -
to get bitrate calc's go to the TOOLS area
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
DVD to DivX - settings for better quality
By CodeMaster2008 in forum DVD RippingReplies: 11Last Post: 14th Jul 2009, 03:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
Rip DVD to DIVX with the same quality
By jujuandhuhu in forum DVD RippingReplies: 20Last Post: 12th Apr 2008, 13:43 -
Divx to DVD and quality loss
By marioval in forum Authoring (DVD)Replies: 5Last Post: 21st Jan 2008, 16:05 -
Better quality DivX encodings???
By smt_88 in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2007, 00:13
