  1. Setup:
    P4 Pc with loads of ram and ATI All in Wonder 7500 Card.
    Pioneer Laserdisk with SVHS Out
    Sky+ UK Digital Satelite Box.
    Nec 1100A DVD Writer DVD+R/+RW
    Firstly i want to convert all my laserdisk films to DVD and i also want to archive some info from my Sky box from SVHS also. My first attempt was not bad BUT my audio is out of sync. i used NeoDVDPlus set a middle quality and then wrote it all to dvd. i was fairly impressed with the quality BUT as i watched it i noticed the sound was lagging behind and got worse as the film progresses. Can anyone recommend the BEST way of doing it either by Link or a short explaination. once i get the Laserdisk done im sure the same settings will work perfectly for my sky box.
    Many Thanks in Advance
    Mark James
  2. Have you downloaded the upgrade neoDVDPlus yet ? Here are what have been improved:
    1) Improved audio/video sync during live capture
    2) Improved still menu picture quality
    3) Improved still menu picture and slide show quality
    Good luck.
    ktnwin - PATIENCE
