guys i nid ur help this has happened to me more than once... my computer just suddenly reboots when im encoding avi's to mpg... it just happens to a few avis i have no way of knowing what... one day its encoding just fine and another it reboots... its really frustrating... have any of you guys experienced this pls help im desperate... thanks
Encoding puts a heavy load on a CPU , check your BIOS and see if it has a feature that 'shuts down / reboots' machine if the CPU reaches a predetermined temperature.
My Abit and my other machine an ASUS mobo both have onboard temp sensors, using these sensors and this program ->> Motherboard Monitor , you can watch your CPU temps as it encodes.
http://mbm.livewiredev.com/
thanks for the tip.. but are you sure that this is the only cause... i only encounter them on specific avi files.... plus i leave my cpu case open and even put the electric fan in front of it... plus whenever im encoding no other programs are running in the background
I got similar problems using TMPGEnc to encode AVI. It's very unpredictable. Until my system totally crashed, no longer boot and I found that I had a bad memory stick, I replaced it and nothing ever crashed since then.
If you could , try a different memory stick.ktnwin - PATIENCE -
Just uncheck the Reboot During Encode option in the preferences.
Update....Um, no there is no such option, it was a joke! -
jsnkc - is there such an option? i checked my version of tmpgenc and there is no option to reboot the pc... maybe your mistaken this for nero....
ktnwin - well that might be the case i mean the memory chip... havent thought of that.. thanks for the help. -
SVCD2DVD v2.5 Reboots PC
By ritzchef in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 20th Mar 2009, 08:29 -
System shuts down and reboots every 13 days?
By tinoman1 in forum ComputerReplies: 7Last Post: 28th Apr 2008, 00:04 -
pc reboots when wow starts up
By Mr anderson in forum ComputerReplies: 8Last Post: 26th Aug 2007, 07:01 -
pc reboots if i touch the case
By bigmicka in forum ComputerReplies: 10Last Post: 1st Jul 2007, 05:12 -
Machine reboots itself...
By The Fred in forum ComputerReplies: 17Last Post: 12th May 2007, 17:58
