Hi,
I have a DTS Audio CD and I would like to play it on the PC.
Unfortunately I do not have digital output from my soundcard, so the only way to listen it on the two speakers.
Can anybody give an advice which program or codec I should use to listen to this CD? Now I can hear only noise when I play it with the Windows Media Player.
Thank you for your help in advance.
Results 1 to 1 of 1
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 08:17 -
Possible to listen to BDRebuilder audio streams before encode?
By Killingtime01 in forum Blu-ray RippingReplies: 3Last Post: 19th Mar 2011, 10:04 -
listen dual audio same time
By wmpatterson in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2010, 16:03 -
DVD Audio Extractor can't listen audio preview
By lupio in forum AudioReplies: 8Last Post: 26th Apr 2010, 11:51 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42
