I would like to delete a few frames of a home-made mpeg2
video file. I tried both TMPGEnc and bbMPEG but could
not cut the video correctly as these tools are not
frame-based.
Could someone please point me to a tool that supports
frame cutting. Thank you very much for your help.
<font size=-1>[ This Message was edited by: dudeman on 2001-10-04 19:29:51 ]</font>
Thank you very much for your quick reply. I just sent you an email.
I hope I'll hear from you soon.
Thanks again
<font size=-1>[ This Message was edited by: dudeman on 2001-10-04 19:30:29 ]</font> -
TMPGEnc edits on the frame for me. With NTSC at 29.97 fps using the cursor keys in cut/merge edit screen I can move in 0.03 second steps which is one frame. Remember by not editing on the I frame the clip will be reencodeded and may give you some blocking.
Thank you for reply but I'd tried that too. The calculation works sometimes but not always.
For instance in one mpeg2 file (encoded with a 2pass VBR settings) that I have, even if
I specified TMPGEnc to chop out the first 30 seconds, I always end up with a 29 second
clip (I verified this using DVD2AVI preview function). I even tried to increase range to 31 secs
(00:00:00 to 00:31:00) and still ended up with a 29-second clip. I don't know why TMPGEnc
does this but it just does. I think this could be why the developer of TMGEnc/MPEG tools did
not include a control to specify frame since s/he knew that it would not work all the time.
Any way, thanks again for your suggestion.
<font size=-1>[ This Message was edited by: dudeman on 2001-10-04 19:31:10 ]</font> -
I guess some ppl are luckier than others. Good for you
Anyway, thank you to all who've replied. Case closed.
<font size=-1>[ This Message was edited by: dudeman on 2001-10-04 19:32:10 ]</font>
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Editing a Mpeg2-PS file
By too2buff in forum EditingReplies: 5Last Post: 26th May 2009, 10:12 -
Problem editing HD mp4 file with sony vegas
By excelsion in forum Newbie / General discussionsReplies: 1Last Post: 24th Jan 2009, 22:08 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
Problem Editing AVI File
By pbmc59 in forum EditingReplies: 8Last Post: 11th May 2007, 06:05
