Hi,
I am trying to convert a divx file to a Mpeg2 for dvd burning later on with the size of 338mb so I can fit 13 episodes on 1 dvd. However when I try to convert with Tmpeg, the lowest output i can get is 356.61mb with an audio bitrate set at the lowest (64kbits/sec).
How can I get the file to the desired 338mb and not sacrifice the audio quality? I've tried lowering the video bitrate but the minimum file size is still 356.61.
Any suggestions will be greatly appreciated.
What are your settings in tmpge? are you using cbr? if you are just use a bitrate calculator and figure it out that way?
It is set on CBR. I've tried changing the bitrate and I still can not get to the desired 338mb. Where can I get a bitrate calculator?
https://www.videohelp.com/calc.htm
I like this one. you can set the exact size you want in. good luck.
Having trouble getting mkv to mpeg2 with FAVC
By Onceler2 in forum Video ConversionReplies: 1Last Post: 31st Jul 2011, 17:14 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
Remove subtitles from MKV when converting with TMPEGEnc
By ikarishinji41 in forum Video ConversionReplies: 3Last Post: 10th Dec 2009, 10:21 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 04:36 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24
