I've been smoothly enjoying VCDEasy for awhile now, but recently had a few major problems which I think might be related...
Ok, I usually do authoring and burning of VCD's, SVCD's, DVD's and Hybrid enhanced discs on W2k. For authoring I use either Pinnacle DVDImpressionPro or Maestro (DVD) or VCDEasy/VCDTlkt/Nero (VCD), with occasional exceptions. For burning, I have been doing most things either through the authoring app, or especially with Hybrids--through Nero.
My burner is Pioneer A04 (Internal IDE). Enough of the background.
Lately, Nero will still do fine with DVDs and DVDonCD, but with (S)VCD it will work one day and not the next, and then work again a few days later. When it doesn't work, it says
(I often will successfully use Nero to burn the BIN/CUE Image).Code:"Bad Parameter. Could not perform start of Disc At Once"
So I tried directly from VCDEasy, similar message.
Also tried to hook up an HP8200e External USB burner, but nothing recognizes it a a burner on W2k.
So I took the BIN/CUE files to a laptop that has 98SE and hooked up the HP burner to it, DL'd the most recent Nero demo. It successfully burned there!!
BUT NO!!...
These discs aren't recognized as discs AT ALL in settop player, are only occasionally on PC's.
The only thing I could think of was that the CUE file had bad settings--something to do with the VCD having chapter/entrypoints.
So I made a nearly identical structure from within Nero, but without the chapters (obviously since Nero doesn't support that), burned it...
SUCCESS!!
So, what does this mean? Anybody had similar problems? Solutions/Workarounds?
I'd still like to do hybrid discs w/ autorun and chapters if possible.
TIA,
More Info:
Took the laptop home last night,
Hooked it up to my Yamaha CR-F1, burned same VCDEasy discimage as before. Burned OK...
Works perfectly! Chapters, PC Autorun and ALL!
Ok, now was it just iffy burners? (HP) or bad/complicated cue sheet? or both? or neither?
Anybody?
I'd guess it's probably a burner issue. I have an older internal 8200-series CD-RW, and it doesn't work very well in DAO/SAO mode. TAO works fine, though. It may be possible to update the firmware, but I know that HP bought the drive mechanisms for the model I have from at least two different manufacturers (one high quality, one low quality, both with the same DAO problem). I haven't worried about it because that machine normally only burns data discs anyway, and I've burned hundreds of those with no problem.
Womble mpeg video editor I get "No disc or disc error"
By pumpkinslion in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2010, 20:32 -
"can't read disc, check disc" problem
By ttheb1 in forum Authoring (Blu-ray)Replies: 1Last Post: 13th Jun 2010, 07:34 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 09:08 -
False "Unsafe Unmount of USB" error msg. from W2K
By Seeker47 in forum ComputerReplies: 5Last Post: 7th Dec 2007, 15:57 -
JVC SR-MV40US "Disc Error" on ANY dvd/cd ... a known COMMON flaw?
By ggoat!!! in forum DVD & Blu-ray RecordersReplies: 7Last Post: 10th Nov 2007, 03:58
