  1. I've tried HP, Verbatim, and Sony, and have had no luck.
    They play on my cheap Magnavox, but not my RP56, which I use in my theater.
    Any help would be appreciated!
  2. I read an article once about Panasonic DVD players and the DVD+R/+RW format. The article indicated that Panasonic DVD players do not support this format because it is the rival to their DVD-RAM. I thought this interesting so I checked it out. Sure enough, none of my DVD+Rs or +RWs would play on my friends Panasonic DVD Changer (can't remember the model number). It played -Rs and -RWs just fine.
  3. It'll work.
    http://www.dvdplusrw.org/resources/compatibilitylist_dvdvideo.html
    What method are you using to burn? Record Now Max from my experience burns the best. All the DVDs I used burning with Record Now Max worked on Stand Alone's compared to Nero. (Just burned the VIDEO_TS and AUDIO_TS).
    Also, what resolution and bitrate are the DVDs in? Some DVDs are stubborn when it gets to that stuff.
    I use memorex, verbatim, and maxell.
  4. I've been using DVDXCopy to burn. I'm a newbie to this, so maybe I'm not using the best program.
    I'm looking for the most accurate copy as far as picture quality, because I want to be able to play these on my big screen, and have heard that some of the other programs cause the film to look terrible.
    Anything you could recommend?
  5. read through the site you will find what you want im new and ive found this site propa
