hello, i have just set up my tv card to capture video directly to vcd format. However, after following the guide in vcdhelp.com, i have run into a problem, the software is older than that which i have. There is a setting on the following page https://www.videohelp.com/ATI_AIW_Guide.htm
for motion estimation quality. In my version there is a possible 100, whereas there is not on this program, my question is whether i should choose 99 as indicated on this page or choose 100. I should also not that the standard setting in the newer version that i use also sets the 1.15 setting as 1.13, as well as the motion estimation qualtiy at 100, anyways i hope someone can help me out with this, thanks a lot in advance.
Do 99 as 100 may drop more frames. Try 80 if you still drop. Set estimates to highest numbers you can, and only lower if drops frames.
Read the VHS->DVD guide below too, as you may pick up a few tips there for using the ATI card.
And I'd suggest ATI MMC 7.7 over all other versions (including new 8.1). And be sure to use the newest April 2003 ATI drivers.I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
Hello! I too just set up my ATI AIW 128 PRO on WinXP Pro. I was wondering what version would be compatible with this type card? The original cd I had was version 7.1. I was wondering if I could use version 7.7 on a 128 Pro card? Please advise. Thanks!Originally Posted by txpharoahThanks and regards,
RayBan
ATI 9600 Pro; Abit BH7; P4 2.4Ghz 533; 1G PC2700 DDR; Toshiba SD5002 DVDR; WD 120G 8MB 7200 Capture Drive & 160G 7200 Program Drive; Pinnacle Studio 9 and Nero6 -
thanks for the reply... i just wanted to clear up something that you had mentioned, i am running a p4 2.4 with 256 ddr ram... so its quite fast, is 100 motion estimation quality the right setting for vcd 2.0? also i am using a nvidia card with the ati tv wonder pci, thanks again.
rayban,
Yes, MMC 7.7 will work on non-Radeon cards.
ATI readme file for MMC 7.7, says for Radeon cards only and it works on my non-Radeon anyway.
Has anyone gotten MMC 7.9 work on non-Radeon?
I tried MMC 8.1 and have not gotten it to install for my non-Radeon card. -
thanks for the info, Ron....I will definitely download that version. Was there anything else you did to make it work or just install it?
Thanks again!Thanks and regards,
RayBan
There is a XP drive update at: http://v4.windowsupdate.microsoft.com/en/default.asp
For non-Radeon ATI AIW cards.
My TV tuner started playing after I made this update and rebooted.
Yes, MMC 7.7 works with non-Radeon ATI AIW cards.
FYI!! MMC 8.X only works Radeon ATI AIW cards. -
Thanks, Ron..I'll give it a try tonight. What order should I load the whole thing?Originally Posted by Rond66
1. WDM driver
2. ATI Display Driver
3. MMC 7.1
Do I need to install SP1 and DX9 also for XP?
Thanks in advance.Thanks and regards,
RayBan
What Linux OS are you Using for MultiMedia ?
By 16mmJunkie in forum LinuxReplies: 30Last Post: 5th Nov 2009, 03:24 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 04:14 -
window media encoder 9 and Diamond Multimedia ATI TV Wonder HD 600 USB 2.0
By nick7920 in forum Video Streaming DownloadingReplies: 1Last Post: 1st Oct 2008, 17:52 -
How do I change the recording folder in ATI Media Center?
By yoda313 in forum Capturing and VCRReplies: 7Last Post: 11th Sep 2008, 11:29 -
Multimedia Center as effective software
By redrock1 in forum Capturing and VCRReplies: 0Last Post: 30th Oct 2007, 14:55
