Have wedding reception as DV AVI straight from VHS via the DV cam.
File is 1:11:42 and is 16 GB.
Added chapters in MF2 and burned to DVD. It came pretty grainy, even the VHS tape was much better.
Thought I read some posts that others had the same problem with MF2.
Any better ideas for encoding it but with still having the ability to add chapters?
Video :
MPEG-2 Video - 4:3 Ratio - 720 x 480 - 128799 Frames
6000 Kbits/sec
Audio :
Linear PCM audio Audio - stereo Mode - 48.00 kHz - 2 Channel(s)
1536 Kbits/sec
I still have the original AVI's.
Any ideas?
The ulead MPEG encoder has not yet been able to match the quality of the good encoders like TMPGenc, CCE or MainConcept.
MF2 is OK though at capturing and authoring so I recommend that you encode the captured AVI using one of the other encoders then load the MPG file into MF2 to do the final authoring.
MF2 can be told not to re-encode the MPG file. -
thanks bunyip, thats what I thought.
Have used TMPG in the past for DVD to DVD encoding. Never have used it using original DV AVI's. Have to check quides again huh?
Any ideas on the best encoder to use to keep the quality from the AVI's?
Thanks a bunch! -
Well, there has been, still is, and ever shall be, a lot of debate on this site about that, it's largely a matter of personal preference.
But as a general guide, for speed and options most favour CCE, its ability to do fast multi-passes at variable bit rate produces excellent quality.
I suggest you do some trials of each product and pick the one that pleases you. -
I was surprised to find out that Ulead's MPEG.now codec was actually developed by MainConcept!
I've tried MC's standalone encoder, and the results are like night and day. Capturing directly into MPEG2 from my 8500DV in VideoStudio 6.0 produces absolutely abysmal results--even worse than using ATI's MMC 7.5.
I haven't tried DVDMovieFactory 2.x, but it's good to have a warning. I was beginning to think that the quality problems were with the 8500DV's codec. -
Originally Posted by CubDukat
Originally Posted by illini19
Go with the bunyip's suggestion and encode to MPG before loading into MF. That is what I do and I am generally happy with the results. As for what to use, TMPGEnc ... CCE ... whatever makes you happy.The glass is neither half-full, nor half-empty.
It is simply twice as big as it needs to be. -
Thanks all. I appreciate it.
I will try CCE next. Had some trouble opening edited AVI's from Premiere.
Get the error in TMPG, ".file.avi can not open, or unsupported" when trying to open the 2 final edited AVI's that were exported out of Premiere as Microsoft DV AVI.
Kind of strange.
Thanks again.
moviefactory 6 plus problems
By steenuil in forum ComputerReplies: 0Last Post: 3rd Feb 2010, 06:35 -
dvd moviefactory 5
By bigz704 in forum Newbie / General discussionsReplies: 0Last Post: 24th Sep 2009, 14:54 -
Ulead Moviefactory
By acw in forum Newbie / General discussionsReplies: 10Last Post: 24th May 2009, 00:51 -
DVD MovieFactory 6
By Mike99 in forum Authoring (DVD)Replies: 2Last Post: 24th Nov 2008, 05:14 -
DVD MovieFactory 6 Plus
By ozab in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2007, 16:48
