The nero5 burning rom software that came with my
Sony DW-U10A is the only video software that recognizes
that I have a DVD burner.
So I downloaded NeroVision Express and bought the
MPEG-2/DVD encoder plug-in that goes with it.
The User's Guide says with MPEG-2, I should
be able to get up to 135 minutes on a 4.7 GB disc.
But I can't even burn 105 minutes to a disc. I get
the message that there's not enough room on the disc,
so it won't start burning. That's after it took hours to
transcode the video.
I suspect that the MPEG-2 plug-in isn't working.
How can I find out if it is working, and correct the problem?
Thanks for any ideas.
--wsr
Don't know why you have the problem but if its too big, then use DVDShrink to srhink your VIDEO_TS folder, then burn the new folder instead. That' should be quick
ktnwin - PATIENCE
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 18:23 -
Is somebody a NeroVision Express expert?
By jeanpave in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2007, 22:42 -
NeroVision 3 Sample format?
By LiBiDoXP in forum Video ConversionReplies: 0Last Post: 1st Jul 2007, 12:50 -
Nerovision 6: 16:9 Stretching to 4:3 on 4:3 Monitor
By markannab in forum Authoring (DVD)Replies: 14Last Post: 30th May 2007, 05:23 -
NeroVision problem
By Flying Doctor in forum Authoring (DVD)Replies: 10Last Post: 23rd May 2007, 00:52
