Sup ppl,
I am having problems opening a movie from tmpgenc. Im trying to convert American Beauty (DivX).avi and everytime i try to load it, it keeps popping up saying: File: "C:\documents and settings\B.K\My Documents\Movies\American Beauty DivX.avi" ca not open or unsupported. Can anyone tell me what that means???
Thanks a million!!!
Dark604
Dark604 -
Open TMPGENC.
Under Options Menu goto Environmental Setting.
Under Environmental Setting goto VFAPI plug-in.
Under VFAPI plug-in - set DirectShow Multimedia File Reader to priority 1 or even 2.
This should solve your problem...Huyzel -
That's your very first post? Pretty damn good!Originally Posted by Huyzel"Art is making something out of nothing and selling it." - Frank Zappa
Sup Huzel,
thanks for replying back to me, and i did what you said, it still can't load up. Does the other stuff in enviroment settings need to be change as well?? Or can u tell me why it does that??
Thanks, appreciate it!
Dark -
Check here: https://www.videohelp.com/tmpgenc.htm
Scroll down to TMPGEnc problems.
"Art is making something out of nothing and selling it." - Frank Zappa -
Dark604,
It may be possible that you are missing an A/V codec that is contained within the avi. Run it through Gspot (here in the Tools section) and find out what codecs it uses just to make sure you have them. May contain AC3 audio which if you dont have the codec will cause TMPGenc to not work. -
If Gspot doesn't work, run it through AVICODEC. You can get it from the tools section also.
Encoding problems
By cdaters in forum ffmpegX general discussionReplies: 8Last Post: 2nd Feb 2010, 19:27 -
Encoding problems
By El Barto619 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2009, 22:32 -
Problems with Vimeo Encoding
By Xenon77 in forum Video Streaming DownloadingReplies: 2Last Post: 28th Apr 2009, 12:04 -
Problems encoding!
By villa99 in forum ffmpegX general discussionReplies: 4Last Post: 25th Mar 2009, 12:50 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 11:30
