i have an xvid that plays fine in my divx player but window media player only gives off a green tint. Also when i use virtual dub and tmpgenc it says that it can't decompress the audio source. Thanks for the help.
Get Gspot from the Tools section and test your file, it will tell you the required codecs and if they are installed.
Color streaks appears once converted to Xvid
By 24fps in forum Video ConversionReplies: 5Last Post: 17th Jan 2011, 04:45 -
Huffyuv to Xvid color correction - advice please
By spicediver10191 in forum Video ConversionReplies: 12Last Post: 11th Apr 2009, 10:03 -
Xvid 8 bit color depth resoultion problem
By afcoff in forum Video ConversionReplies: 4Last Post: 24th Feb 2009, 00:50 -
Which backlight color for portable electronics blue, green or white?
By yoda313 in forum PollsReplies: 8Last Post: 5th Nov 2007, 09:58 -
Remove green color from 49 frames
By mlong30 in forum EditingReplies: 5Last Post: 11th May 2007, 00:54
